06-27-2023 11:43 AM
My data was used up while not even using my phone, and I didn't even get the text message saying I've used 95% of my data like usual, only the one saying I used 100% of my data. Asking me to buy more, and I did , but withing 15 minutes, I got another text saying I used 100% of my data and wanting me to buy more again.. why is my data being used so quickly when I'm not een using my phone
06-27-2023 01:29 PM
HI @Luciebab did you check if your phone really using the data? If it uses the data that fast, maybe some backup to cloud job running
06-27-2023 12:40 PM
Thank you sent a message.
06-27-2023 12:14 PM - edited 06-27-2023 12:16 PM
There was a glitch in the system for some members showing extra data usage.
You might be one of them so contact a CS_Agent by private messaging on your computer with the envelope icon or click on your avatar them Messages.
06-27-2023 12:07 PM
we used to get those warning messages when we got close to running outta data...but they don't do that for a few months now.
Go in to your phones settings and disable Data to apps that you don't usually use on a regular basis.
Also, log in to your account on a laptop and try this...
06-27-2023 12:05 PM
@Luciebab- Are you sure you don't have some app in the background using your data? Is your WiFi connected & working?
