11-27-2021 10:42 PM - edited 01-04-2022 05:05 AM
Hi guys, has anyone noticed any problem with their internet using data nowadays because mine becomes really slow or stops working, then I have to turn data off and then turn it back on
11-29-2021 10:37 AM - edited 11-29-2021 10:37 AM
@Yasaman2 wrote:I tried all things mentioned. Its still slow. Is North York area including the areas they are working on internet?
There are many areas working on the 5G upgrade and honest, we don't have their schedule and plan. One of the members here is a expert in the field and he sometimes will update and confirm us on the area.
You might want to open ticket with PM to confirm if it is due to the upgrade or if might be network tower issue.
To open ticket with PM:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
11-29-2021 10:32 AM
11-29-2021 10:21 AM
North york, Toronto
11-29-2021 10:20 AM
@Yasaman2 which area you are at? (province and city)?
did you try what suggested above? reboot the device first, see if it helps. Then change to 3G Only on the network and see if it is good.
Telus and Bell are both upgrading their network to 5G and that might affect some locations temporarily
11-29-2021 10:17 AM
Hello, I found my internet speed much slower than before, it sometimes can not even open the websites. I didn’t change my plan or something. Just the speed is noticeably lower than before
11-28-2021 12:58 PM
Try clearing your cache and cookies then reboot.
11-28-2021 12:51 PM - edited 11-28-2021 12:52 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
11-28-2021 12:43 AM
i also experience the same issues. there are many factors, but what I've noticed is that if a tower is over saturated, PM customers are kicked off and reconnected to a further tower causing worse/slower data connection. this is why you are able to get a better connection when you enable/disable your data because you are reconnecting to the closer tower. eventually one will just get kicked off again.
this usually occurs when my connection shows LTE and not LTE+
11-27-2021 11:29 PM
@winston11 wrote:Hi guys, has anyone noticed any problem with their internet using data nowadays because mine becomes really slow or stops working, then I have to turn data off and then turn it back on
@winston11 - Perform a Reset of your device's Network Settings, see if that improves going forward.
iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
11-27-2021 11:05 PM
@winston11 did you try changing the network to 3G Only?
Bell and Telus has been busy upgrading their 5G systems and it might affect the LTE system in the area when they are working on the 5G. .. Try changing to 3G only and see if it helps.
11-27-2021 10:50 PM
Noway I dont keep it on all the time I just have 1gb
Its just when I turn it on and working on something it just stops then I have to turn it off and back on
11-27-2021 10:45 PM
@winston11 : If you're one who leaves their data on all the time then it's kind of a good thing to kind of reset it on occasion. It sounds like you're doing that by noticing the slow down and then reseting it.
