Data after reaching the limit
maheshkmurthy
Do data plans cut off upon reaching the limit or do they move to a lower speed?
Although if you force your Plan to renew then you also reset (lose) any Rewards you've accumulated so far during your interrupted billing cycle.
@Poogzley wrote:
Data is supposed to be cut off but it seems that there is sometimes a glitch in the system where you are not cut off, this has happened to me on a few occasions during system maintenance at which point you basically have unlimited free data 😜
Hmm...yes others have also mentioned some of these unofficial glitches which sometimes work in our favour.  Hopefully, PM mods don't read these threads and fix this particular glitch:)
Poogzley
dickwong
Good to know that can restart plan early
kelvarnsen
Cut off. You can either buy more data, get the mods to restart your plan early or change to a different plan and start it immediately.
