Data add on never added
06-13-2022 11:00 PM
I purchased a Data Add on for 1 GB on June 15, I was charged $17 yet I have never been able to use it, whenever I connect the mobile data I must sign on the Public Mobile network and all I get is a "Internal Server Error"... I feel ripped off. How do I get a refund since I have paid for a service I am not receiving?
Thanks
06-13-2022 11:51 PM
When you log into your self serve account do you see $15 in your available funds? If so you can now purchase the $/1gb data add on. As mentioned by @softech you only completed the first step of buying a data add on. Keep in mind your account is like a vending machine. You have to add the money first then make your selection, confirm and submit your payment.
06-13-2022 11:44 PM
@BKNS27 what i meant is when user get that from general internet access not specifically from tying to login to My Acxount site
Your experience is different , as you said, you got it when you try to access My Account
06-13-2022 11:37 PM - edited 06-13-2022 11:40 PM
I tried login into my account last month and I got the same message and I am on AutoPay and I have only used about 0.5gb. I couldn’t login to my account but login the next morning and it showed I used 0.4gb.
Hmmm strange but good to know.
06-13-2022 11:23 PM
@BKNS27 actually if user trying to access internet and go "internet server error", that usually means user is out of data
06-13-2022 11:22 PM - edited 06-13-2022 11:24 PM
The Internal Server Error means the the PM website is undergoing maintenance. I was able to login so give it a try now. This happens frequently so don’t worry about it.
If you were charged then the Add-on should have been added to your account.
Meanwhile, just reboot (power off) your phone and see if that works.
06-13-2022 11:03 PM - edited 06-13-2022 11:03 PM
@JFigueredo Buying add-on is a 2 steps process:
1. Load Fund
2. Actual buying of the addon
Many people only loaded fund and not aware of Step 2. Any chance you missed step 2 , too
check My Account, if you see $15 sitting as Available Fund there, then you only did Step 1 but not Step 2. If that is the case, you can go back and buy. PM will take the money from available fund there and won't charge you again
After buying, Available fund should be down to $0 , just reboot your phone once
