10-30-2022 01:30 PM - edited 10-30-2022 01:32 PM
A new day, a new question……
I upgraded my plan yesterday to the new special, $40 for 4GB and 15GB of data. I turned on my data 45 minutes ago, and have been trying to download a picture for the same length of time. I’ve rebooted my phone twice, and turned my wifi off, and it’s still stuck in downloading. Now that I have a whole lot more data, I would like to use it. Can anyone advise me what to try next? Thank you so much.
oh, my new plan started today as it’s my renewal date.
10-30-2022 10:16 PM
Thankyou! Almost exactly what I received from the moderator….. I’ll go back in and fill in the spots that he missed giving me. I wondered why he didn’t mention the last few things there.
10-30-2022 10:12 PM
Thank you….the moderator gave me all the information I needed to fill in those missing things in the APN section.
10-30-2022 10:07 PM
I know I’m sending this to myself, but I don’t know how else to do this…..I want to thank you ALL for your patience and understanding while trying to help me with this problem. It is very kind of you all! My data is now up and running, and it should be fine from now on. Virtual hugs to you all!
10-30-2022 06:40 PM - edited 10-31-2022 12:32 AM
10-30-2022 06:21 PM
It's not hard to put in. If you found your way to seeing no APN's listed then tap Add or + and start typing. Save. Select as the current APN. Go in and then out of airplane mode. Try browsing to a page.
10-30-2022 05:45 PM
Thank you! I’m just waiting for the agent to get back to me. Thank you for this valuable information!
10-30-2022 05:42 PM
lol…actually, that’s exactly what I’ve been doing ever since he replied to my message. Thaks so much for your input! I appreciate it!
10-30-2022 05:34 PM - edited 10-30-2022 05:35 PM
lol stop clicking on things. just let the agent help you. and the next time you would like to make any changes to your account please just come to the community. 🤣
10-30-2022 05:33 PM
While you're waiting between replies from them:
APN: sp.mb.com
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
APN Type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Mobile virtual network operator: 4D
Other fields should come in as default or just leave them be.
10-30-2022 05:28 PM
Actually, we just realized that there isn’t any APN entered. I’m now working with an agent, and hopefully he’ll be able to help me. Thank you for your input.
10-30-2022 05:18 PM
Can you provide images of your APN settings? Perhaps something is slightly off.
10-30-2022 04:59 PM
Thanks, I just cancelled it.
10-30-2022 04:58 PM
Android
10-30-2022 04:36 PM
Without looking in your history...for this thread, what phone are you using? iphone or Android?
10-30-2022 03:42 PM
@TessieBoo You can cancel the scheduled plan change before the next cycle as it shouldn't be necessary. Send a private message to CS_Agent instead if you're having problems with the ticket. You should be able to verify with your phone number.
10-30-2022 03:22 PM
Great…..now I can’t put in a to open a ticket because it won’t accept my password, or my pin #. I went into my account, and changed my pin#, and it still gave an error message . Now, this morning when I went into my account, it reflected the new plan, and it looked like the new rate was charged to my credit card. I just checked my statement, and the charge for the new plan is on there. This afternoon when I went in to my account, it was showing the old plan. So, I once again chose the new plan to start next cycle….I’ve probably really screwed things up now.
10-30-2022 03:04 PM
Thanks so much! Am going to open a ticket now.
10-30-2022 03:03 PM
I tried everything except trying the SIM card in another phone because I don’t have another phone to try it in. I’m opening a ticket now. Thanks for your help.
10-30-2022 02:40 PM
you need to contact customer support to fix your account because you most likely messed it up. if your renewal is today and you changed your plan yesterday without manually adding $40 to your account. then the account didn't provision correctly
10-30-2022 02:25 PM - edited 10-30-2022 02:25 PM
No, softech, it is not working at all. I’ve always had trouble with getting the data to work. A friend of mine is with PM as well, and he’s never had trouble using his data. Thanks, I will open a ticket….that is if I can remember how…lol
10-30-2022 02:12 PM
@TessieBoo if the data works, but just slow, yes, wait until it is after 48 hours
but if you are not downloading at all, then open ticket with PM support
10-30-2022 02:09 PM
Ok everyone, I’ll leave it for a few days, and try it again. I didn’t expect it to be instantaneous, but thought I would still have 3G.
Thanks everyone for your kind help….lol…hope it all comes together in a few days, or I’ll be back.
10-30-2022 02:07 PM
@TessieBoo Yes, the data should still work regardless of what speed it may currently be. If the suggestions haven't worked, then contact customer support as suggested.
BTW, did you try removing your SIM and rebooting the phone, or try it another phone and reboot and then back and reboot?
10-30-2022 02:02 PM
I changed it yesterday, and my renewal date is today. I went into my account this morning, and my plan is changed to the new one. I thought it would still work, but on the 3 G.
10-30-2022 01:58 PM
Yes, but I’ve always had data, would shouldn’t it still work?
10-30-2022 01:56 PM
@TessieBoo there were some posts about data issue after plan changed. Seems like you tried everything you can on your end, just open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-30-2022 01:55 PM
Yes, I logged in this morning and my account shows the new plan with the 15GB of data@4GB now, and not 3. I’ve had 2GB all along until this upgrade, and I’ve always had trouble getting it to work for me.
10-30-2022 01:51 PM
Ok, I removed the SIM card, and put it back in, and it’s still not downloading, just spinning. Perhaps I should try rebooting again?
10-30-2022 01:49 PM - edited 10-30-2022 02:04 PM
@TessieBoo The data speed takes upto 48 hours to change after a plan change from 3G to 4G. When did you change your plan?
edit: oops, nvd, didn't read the question properly.
10-30-2022 01:44 PM
If you upgraded from 3G to 4G, full speed will be available in a few days. It is not instantaneous.
