03-10-2020 06:38 PM - edited 01-05-2022 09:53 AM
I am on a plan with 1 gb of data and had 2 promotional data add ons of 1gb each (2 gb in total). One of the promos was the Free Holiday Giveaway and I don't remenber the other one. I used just over 1gb of data this month and it deducted the usage from all 3 data places (my plan and both promos). I should have 2 gb of data left but I have no data at the moment. Is this intended or an issue?
03-10-2020 08:39 PM
@dabr wrote:@Nezgar Are you saying the 75% and 95% notifications don't happen for any data (plan+add-ons), or just for the add-on data doesn't receive the usage notice but the plan data would?
It appears to be no data usage warning notifications at all until all of your data add-on's are consumed and gone from your account.
03-10-2020 08:00 PM - edited 03-10-2020 08:39 PM
@Nezgar wrote:I've observed that the usual text notifications when 75% and 95% of your data is consumed are not sent when you have any kind of data add-on active on your account, which makes it pretty easy to unknowingly use all your data.
No notification for base plan data OR add-on data. Pay special attention to your phones data meter and the selfserve totals.
Edit: I thought I remembered reading some other posts mentioning that the notifications don't get sent for the add-on data but the plan data did receive the usage notification, but I see you say it applies to both base and add-on data. I'm sure the lack of notifications is creating all the confusion for customers when they see all the data gone and no warning. Not the most ideal of situation for sure.
03-10-2020 07:55 PM
03-10-2020 07:47 PM
Thanks. I saw your this response after I accepted the other response. I check my phone data usage and I had used close to 3 gb in the last couple of days.
03-10-2020 07:29 PM
If your overview page, after login, does not show any usage lines, this means that you had used your plan 1GB data and both bonus add-ons as far as PM server is concerned.
The following is my data usage lines:
| Data & Add-Ons | Amount Used |
$0 Free Holiday Giveaway: 1GB Add-on | 140.206 / 1024 MB |
$0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US) | 1 / 400 MIN |
100 Minutes Canada-Wide Talk | 72 / 100 MIN |
1GB Promo | 102.004 / 1024 MB |
250 MB at 3G speed | 169.737 / 250 MB |
500 min Canada-Wide Long Distance | 0 / 500 MIN |
Only moderdator can access your account. If you think that PM server is wrong, you can create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
03-10-2020 07:03 PM
@bukunolamobile wrote:Hi,
I checked my usage for the last 30 days in the usage history tab and it says 1208.498 MB and 3.906 MB which comes to around 1GB. The wifi in my place was going to be down so I checked to make sure I would be okay during the outage. I had used just over 250mb in one and 0 mb in the other one at the start of the month.
Do you have phone usage data to help track usage?
03-10-2020 07:03 PM
@bukunolamobile if you feel that the data usage history is in error, contact a moderator and ask them to to check it for you. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
03-10-2020 06:54 PM
Hi,
03-10-2020 06:41 PM
@bukunolamobile wrote:I am on a plan with 1 gb of data and had 2 promotional data add ons of 1gb each (2 gb in total). One of the promos was the Free Holiday Giveaway and I don't remenber the other one. I used just over 1gb of data this month and it deducted the usage from all 3 data places (my plan and both promos). I should have 2 gb of data left but I have no data at the moment. Is this intended or an issue?
You would have to go back in 30 day increments to figure out where all of your data has gone. If you have used over 1GB this month (remember PM plans are based on 30 days so calendar month doesn't work) you would have gone into one of your add-ons. This could have happened over many cycles
