09-12-2025 09:18 PM
We have a tablet that uses the 4G network to connect to the net. It uses a SIM card ....I forget what they are called but the SIM card is a standard one for phones, in size, its around a centimeter square.
If I sign up for Public Mobile on a 4G plan, will the SIM work in the tablet allowing access to the internet over the 4G network? We would not use it for phone usage, as its not a phone...
TIA
09-13-2025 10:35 AM
Make sure the tablet is unlocked. It may not work if it’s aligned with a certain provider
09-13-2025 08:05 AM
Yes it will work for data. Calling and texting will not work. These services will only work if you put a sim card in a compatible Samsung phone and sync it with your tablet.
09-12-2025 11:52 PM
@BoogeyMan3 wrote:I sent a PM to the CS agent on this, will see what they say. Its a Galaxy A7 Lite
Asking CS_Agent wasn't needed. Public Mobile doesn't block devices from using data.
09-12-2025 09:43 PM - edited 09-12-2025 09:43 PM
the PM sim card will work on Galaxy A7 Lie. Basically as long as the tablet has compatible bands on PM network, the sim will work on it
09-12-2025 09:35 PM
09-12-2025 09:29 PM
@BoogeyMan3 wrote:We have a tablet that uses the 4G network to connect to the net. It uses a SIM card ....I forget what they are called but the SIM card is a standard one for phones, in size, its around a centimeter square.
TIA
In all honesty @BoogeyMan3 it's truly a hit and miss. Nobody really knows even though they try. I would try to find someone who has Public Mobile and borrow their SIM card and try it out. Or if you feel like wasting $20 to find out, you can do that too. And if it works, then you can get whatever plan you want with the data you want. Never say never. However if it does work, can you come back and share what tablet it is, make and model? We're always interested in what works.
