DOWN GRADING PLAN
ping8458
Hi,
Currently on the $25 plan.  If I change to the $15 plan do I lose the Holiday Free Giveaway I've accumulated over the past couple of years that I haven't used up yet.
Ping
9 REPLIES 9
KamP
No you won’t be loosing it. You will still able to use them even after downgrading the plan. Thanks.
pkaraa
no Holiday Free Giveaway dont expire until used up and remains in your account even if the plans are changed.
@ping8458
No the Holiday Free Giveaway is will keep in your account until you used them no expires,
and Click Here link  to you know how to Change Your Plan online,
darlicious
@ping8458
Nope you won't lose them. You may want to add the $5/500min add on for a little insurance should you deplete your 100 outgoing minutes on the $15 plan. Your holiday international minutes will work as Canada wide minutes but if you can use them to call friends and family then saving them ($0.05/min)for that purpose makes more economic sense and purchasing the Canada wide add on ($0.01/min) instead.
@ping8458 No worry, your Holiday bonus and other add-ons that you purchased will stay with you  🙂
Meow
All accumulated rewards including bonuses will stay on your account.
Triguy
They would remain in your account until they have been used up.
Quigley
@ping8458   No you won't lose those add-ons.
The one-time holiday giveaway data add-ons (from both years) won't go anywhere after changing plans.
