07-04-2023 03:29 PM - last edited on 07-04-2023 03:51 PM by Alex_G
DATA NOT showing on my phone.....I have: Adds on 2GB + 2GB Minutes inter: 54 +500
Subscription usage : 1GB
Sim card# 891xxxxxxxxxx
Add-Ons
07-04-2023 05:25 PM
Your account will give you the updated data usage than the phone data app because PM is on a 30 days cycle and not a monthly cycle which the apps will be using.
Just login to your account to see what is the actual data usage.
07-04-2023 03:51 PM
@BB15 - to check what you have left for data usage, call 611 from your device. Here you can check what is remaining for data on your account (this includes any plan or addon balances remaining).
If you do have data left, then check your phone to see if you have a data limiter set on it. If so, adjust it or turn it off so you can use your data.
If you do have data left and don't have a data limiter set, try your SIM card in another phone and test for data.
Some things to try for finicky things:
- restart phone
- toggle into / out of airplane mode
- reset device's network settings
07-04-2023 03:47 PM
Hi @BB15 Login My Account again using Incognito/private/secret mode, you could see different amount of data left.
07-04-2023 03:38 PM
@BB15 Be sure you still have data left like this
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
of something is miss you can ask support to investigate
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-04-2023 03:35 PM
@BB15 this is an open forum and it is dangerous to post your sim number here. Please click the down arrow on the top right of your post, click Edit Message and remove it
For data, it could be a cache problem and ehatbyiubread earlier could be outdated, please login My Account again using Incognito mode and confirm how much data you have now
If you really still have data left, reboot your phone once. And if you are on Android, disable the data limiter
