DATA PLAN ONLY
10-16-2018 09:13 AM - edited 01-05-2022 02:10 AM
10-16-2018 07:37 PM
@Anonymous wrote:
@syantixmanjah wrote:Including Vancouver?
Please do banish this @will13am. My apologies. I wondered as I was typing that in...am I helping a competitor?
syantixmanjah...read something. It's all there.
Not me.
10-16-2018 06:19 PM
@syantixmanjah wrote:Including Vancouver? @will13am @austinhuang
Yes, all of Canada including Vancouver. I suggest you take this discussion offline because this thread is going be banished.
10-16-2018 05:44 PM - edited 10-16-2018 06:29 PM
10-16-2018 05:35 PM
10-16-2018 05:34 PM
including Vancouver?
10-16-2018 03:08 PM
yes, I agreed with will13am. Data should work anywhere in CA
10-16-2018 02:56 PM
@austinhuang wrote:tbaytel only works for Thunder Bay, ON tho.
Wrong. It works throughout Canada.
10-16-2018 11:13 AM
10-16-2018 10:40 AM
@syantixmanjah for data only plans, Tbaytel is probably the best option. $100 every 365 days to sustain a bucket of non expiring data.
10-16-2018 10:09 AM
for data only plans PM is not the place yor you. your bets are probably koodo if you have an account with them 15$/month for 3gb data or fido similar plan you are supposed to have an accountto get that plan but there are reports that it can be had without an account by going to fido resellers (not fido branded stores)
10-16-2018 09:35 AM
Public Mobile cheapest data only plan presently is:
250 MB for $20 per month, but it does not roll over the used amount.
10-16-2018 09:27 AM
What is your talk/text requirements ? There's some great prices on combination packages for the lighter users. Additionally, there seems to be FLASH sales periodically that might just be of interest to you. Good luck.
10-16-2018 09:24 AM
At present, the plan that makes sense for your needs with Public Mobile:
$10 per month 50 minutes/50 text (with autopay, $2 per month discount)
Add on roll over data $30 for 1 GB. This unused data does roll over to next month.
If this does not meet your needs, then possible other companies might.
