01-27-2023 07:33 PM
Last time i request you add my other bank account number and autopay im unable to login in my account but there is not
01-27-2023 08:31 PM
@hTideGnow- Please go back and strike out that thought in your earlier post.
01-27-2023 08:26 PM
Hi @dust2dust my mistake, it was just suspended.
as long as @AJ16 follows the instructions to get back to My Account and add the visa debit or buy voucher, it will reactivate
01-27-2023 08:25 PM - edited 01-27-2023 08:54 PM
@AJ16 if it’s been over 90 days as @hTideGnow mentioned then account is closed have to start new account and I would start by changing this number that associated with any bank email etc , now that is on public forum just for your personal safety
edit so it sounds as thou you account is just suspended and not closed , but I still stand behind changing your number that’s associated with bank email and any other services you have now that it’s been compromised
01-27-2023 08:24 PM
@hTideGnow- Nice. I didn't want to try in case it sent them the text and confuse them more. But good for you to do it.
01-27-2023 08:23 PM
Hi @AJ16 , sorry, my mistake, you number was just suspended
But can you login to My Account? if you cannot, then open ticket with PM CS agent to get the access back first
01-27-2023 08:23 PM
By vocher month of nov 22 active my plan by vicher almost 30 or above dollars
01-27-2023 08:21 PM
Yes may be by bank it is but by vocher i active my plan by vocher
01-27-2023 08:19 PM - edited 01-27-2023 08:42 PM
@AJ16 wrote:##########
HI @AJ16 if that is your phone number, please remove it
But I checked for you, the number has been deactivated, so it has been over 90 days of suspension. Your last payment you made to PM must be more than 4 months ago. Does that sound correct?
nevermind, the account was just suspended
01-27-2023 08:13 PM - edited 01-27-2023 08:15 PM
@edit @dust2dust Already mentioned this to you
01-27-2023 08:08 PM
I was biting my tongue as I wrote that. What part of absolutely should not was misunderstood?
Please click on the little arrow to the upper right of the date and time of your post to edit out the number. I'm not offering to pay for you.
01-27-2023
08:06 PM
01-28-2023
05:40 AM
computergeek541
xxxxxxxxxxxxxxxxx
01-27-2023 08:02 PM
Again, we can't do that for you. If you need that kind of hand-holding then only support can do that for you. They can help you get all properly set up with an account if not already and then you can do this all yourself.
01-27-2023 08:00 PM
Almost 2 hour trying but failure .
Please u add my visa debt on my plan
01-27-2023 07:56 PM
We can't do that for you. (well other than you telling us your phone number which you absolutely should not). Only support can help you otherwise.
But really, it's not difficult. You can go to recharge.com and buy a voucher and they'll email it to you and it will include the voucher code. You dial 611 and enter in the voucher code.
Or you can go to a store like Mobil gas and ask for the instant top up where you give them your phone number. They also sell vouchers but this option is about the instant top up. You could do the voucher option but the instant top up is pretty slick. Then it just automagically lands in your account.
01-27-2023 07:55 PM
@AJ16 we , who replying this post, are all just customers in the Community and cannot help to reactivate your plan
PM only takes Visa Debit or credit card. So, did you get back access to My Account yet? If not, either use Reset Password on the login page there or open ticket with Support as advised above. Once you get back into My Account, you can then add your Visa Debit card onto the system and then manually pay the plan amount
01-27-2023 07:51 PM
I dont know could u please active my plan
01-27-2023 07:49 PM
My paying ideas earlier were so that you can get the service working if it's not. Then you can take your time to have support get your account all straightened out so that you can do this all yourself in the future.
01-27-2023 07:46 PM - edited 02-07-2023 03:00 PM
@AJ16 wrote:I dont know how to creat account i forgot my nformation last time here i share my accont number to add and on autopay.
open a ticket with SIMon Chatboth
typ: Agent
and Click, Contact Us
then Click, Other
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-27-2023 07:45 PM
you likely has an My Account created already.
First try to use the Reset Password link there, enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
01-27-2023 07:44 PM
01-27-2023 07:44 PM
@AJ16 wrote:Last time i request you add my other bank account number and autopay im unable to login in my account but there is not
- Please renew my plan thank you.
@AJ16 if you think you private messaged CS_Agent, you did not. You posted in the public Community Forum.
To private message them go to your envelope, create a new message and type "CS_Agent" in the Sent To field.
Or, other members like you can help you here, on the public Community Forum, and suggest things that you can troubleshoot yourself to find a fix.
01-27-2023 07:39 PM
You can pay to renew your service using vouchers and dialing 611. You can buy them in lots of stores or online. You can also pay using the real time payment method in a few stores.
Did you sign up in a store before last summer? If so then did you create an account after that?
You're asking things that you can do yourself if everything is all set up.
01-27-2023 07:38 PM
@AJ16 We are just customers like you trying to help ..
01-27-2023 07:35 PM
Hi @AJ16
close all browser and clear cache/ cookies/ open inPrivate mode,from computer.try Login again.
