Credit cards not acceptted
lmohan
This is an ongoing situation, your system keeps rejecting my cibc visa and capital one mastercard,
Can i find out what is going on here?
@LoveNature wrote:
Hi @lmohan
close all browser and clear cache/ cookies/ open inPrivate mode,from computer. Login again, and re-added CC,
but using your postcode like that M5J 2V5
if you enter M5J2V5 or m5j3v5 is not accepted and make sure your profile postcode is same your CC..
Capital letters or not don't matter.  It automatically gets corrected to all caps.  Also, typing a space or not doesn't matter.  Pressing the spacebar when typing in a postal code in Self Serve doesn't do anything/doesn't get accepted as a valid character, regardless.
In additional to that, the Self Serve profile address and postal code does not need to match that of the postal code in the billing area.
LoveNature
Hi @lmohan
hairbag1
@lmohan
before you log in to your account...log in on a laptop using incognito mode...then enter the cc info to your account
I dunno about the capitol one...but the CIBC Visa should be accepted.
@lmohan  these are all good cards and should be able to use
But what was the error message?
First, I suggest you wait a FULL hour before trying again as you likely has triggered a temporary fraud lock.  No worry, just one hour
Then try again using Incognito mode or Private mode on Safari.
Or try on a desktop machine
and remember try only 2 times every hour and no more,
if nothing works? then I guess PM support is your friend and have them to check and add it for you
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
HALIMACS
@lmohan
Try using a desktop or laptop device.
When doing so, go incognito or private tab to ensure no caching issues (which the self-serve site is notorious for)
@lmohan  Auto pay does fail at time s find out why so often from support
while your already here and logged in the community
  • you can send a private message to our  CS_Agents by clicking here.
