Phone plan not working
Timtrenholm91
Changed my phone plan added money to my account unlimited Canada wide call text and 3gb of date included in the plan but when I try to use my phone for a phone call it says I’ve used all of my minutes
9 REPLIES 9
@Handy1 wrote:
@Timtrenholm91  Maybe reach out to support
while your already here and logged in the community
  • you can send a private message to our  CS_Agents by clicking here.
To contact customer support agents, members need to be using the chatbot to open tickets.
Timtrenholm91
It just ends the call when I try letting it go all the way through
Timtrenholm91
 No it does nothing but give that message I’ve tried airplane mode I’ve tried resetting my phone multiple times and nothings working
HALIMACS
@Timtrenholm91
If the messaging precedes a phone call, what happens if you just wait several seconds.. does the call eventually ring through and connect?
Timtrenholm91
No I’ve had it for quite a while just decided to change my plan as I was paying 50 dollars and not using all of the data I was paying for
@Timtrenholm91 - if you have an unlimited calling plan and you are receiving that used all your minutes message, restart your phone, or toggle into airplane mode and then back again.
I would also suggest to perform a reset of our device's network settings.
These messages have happened to others with unlimited calling before too. They will eventually go away; I am guessing this is a pretty new activation?
Edit, You could also try adding a '1' in front of the 10 digit number to see if that helps.
If the call goes through just ignore the message. The account should right side itself soon.
LoveNature
Hi @Timtrenholm91
try to reboot device.
@Timtrenholm91
Try  again  incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
