Credit Card Expiring Test Message
BLo
My & I got a text message saying our payment credit card has expired.
I checked it twice and our card is not expired.
Can you follow up on our behalf?
hi @BLo
couple customers had the same problem. Look like another glitch
Just ignore it if you are certain that is not a problem
or if you like support agent to check, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
You can ignore the message as Public Mobile has incorrectly sent this text message out to some customers.
hairbag1
@BLo
please double check expiration date on current payment card...make sure it's not due to be renewed.
