12-01-2023 10:59 AM
Hi there,
New here so not sure if this is normal or not but I keep getting logged out of this Community site after leaving the page for about 5-10 mins which causes me to have to log back in again constantly.
Is this normal or is there a certain way to have it set up?
12-01-2023 11:25 AM - edited 12-01-2023 11:26 AM
If you have trusted device checked off. I found that it depends on who’s wifi I am connected to.
At home, no issues. I need to login again and with trusted device.
Note, I also have VPN enabled and it still works but I found McD free wifi always have to login.
12-01-2023 11:17 AM
I have complained about this myself in the past.
I get logged out after 3-5 minutes myself so I think it's a system issue. I have 2 different phones that I sign on with and have the same issues so it can't be my phones.
Never tried using a desktop yet so not sure about that part.
Oh well🙃
12-01-2023 11:14 AM
@Yummy
ah maybe it's normal then since I have some type of "Memory saver" for my tabs in the browsers I mentioned above so I guess once they kick in, I'm "inactive" so it logs me out.
That's a bit annoying though, like any forum it should just let me stay logged in before I choose to log out.
12-01-2023 11:08 AM
It logs me out after an hour or so of inactivity. But it never logs me out during the session. Then again I never stay 1 hour or more in one session.
Yes, it is a little bit annoying and I miss old Community where you stay logged on until you log off. Way to much security and I would really LOVE to have an option to decide MYSELF how long my session would last.
12-01-2023 11:07 AM
@hTideGnow yup i do! I'm guessing it's maybe a cookie issue so I will reset them and test it out
12-01-2023 11:03 AM
HI @chr15
do you have the Trusted device checkbox at the bottom when you login or getting the 2FA code? check that box
12-01-2023 11:02 AM
hey @hTideGnow
I've tested it with firefox & edge as well and it's the same issue and I'm not sure why.
12-01-2023 11:00 AM
