05-03-2022 02:22 PM
05-03-2022 03:48 PM
Are you a new customer/activation or is this in relation to an already existing account? If you don't want to tell the community your issue and have gone the CSA route give us a heads up as well so we know your matter has been addressed.
05-03-2022 02:32 PM - edited 05-05-2022 05:58 PM
Either way you will have to type out your issue. You can practice on US just dont revealbany sensitive or personal info. Like your phone number.
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-03-2022 02:30 PM
You've made a connection... here, in the Community.
How can we help!!!
05-03-2022 02:27 PM
We're live. Cs_agents are live. It's just all by typing.
What's the problem? Your one word connection can mean a lot of things.
05-03-2022 02:24 PM
By email only
- Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented. If ticketing does not work very fist time do the below.
- Send a private message to the CSA - agent by clicking Here
In either case watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar.
05-03-2022 02:23 PM
@Reggie20 PM support is all online. So, for quick response, submit a ticket quickly:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
Or, if you can share your issue with us, we can try to help and share workarounds 🙂
