10-11-2018 10:08 PM - edited 01-05-2022 05:53 AM
10-11-2018 11:29 PM
thank you. helped a lot
10-11-2018 11:22 PM - edited 10-11-2018 11:22 PM
@shawnk2000 wrote:Pm is public mobile.
You're right. But the context is ambiguous. He might be asking what "G's" PM uses. Dunkman above has that covered.
10-11-2018 11:20 PM
Don't worry. Public Mobile does not use 2G. Public mobile uses 3G/4G.
10-11-2018 11:16 PM
10-11-2018 10:57 PM
tnx
10-11-2018 10:56 PM
Thanks. Says does NOT support 2G network. What is PM? Sorry I know nothing.
10-11-2018 10:29 PM
@lake. I do not recommend that you trust the IMEI checker as a compatibility test. It does not always work correctly for that purpose. If your phone was purchased from a Canadian carrier, it is probably compatible. That said, you should check the specific model using one of the following sites:
10-11-2018 10:27 PM
Your phone should work. You can verify by going to this website for your specific model of Galaxy 6
10-11-2018 10:17 PM
Check the IMEI number, then make sure it's unlocked and then you're good to go. Get a PM sim card, select your plan. Welcome to Public Mobile.
