Checking Data Usage
saharding0005
I just went on the new website and wanted to check my data usage and it says NaN. What does that mean? It will not give me how much data I have used on my plan. I am on the $25 for 1gb plan and wanted to check it since they made all these new changes.
@saharding0005
 PM has fixed the usage counter problem, it is now showing the correct usage
@saharding0005   you can open a proper ticket, message them here:
saharding0005
How do I go about doing that as well?
@saharding0005   you are not alone, I have the same problem.
I have reported to CS agent about the issue.  So, hope they can fix it soon
https://productioncommunity.publicmobile.ca/t5/Announcements/We-want-to-hear-from-you-technical-conc...
@Handy1   it is not a cache issue and hence refresh or incognito won't help.  it is an actual glitch
@saharding0005  Try again incognito or
simply try refreshing the page when logged in
bluejaywpg
NaN stands for "not a number", sort of like dividing any number by zero or something invalid. But whyis it appearing? Good question.
