Charges
Terry65
Have been unable to set up a mobile transfer from my previous supplier to Public Mobile however they have taken my money from my credit card.  What to do now?
10 REPLIES 10
HALIMACS
That’s it? You’re giving up?
Once you get past the activation, it’s usually smooth sailing with no issues around here.
Refunds on prepaid services are not usually provided.
@Terry65
there's no refunds ...as you've already paid, you may as well get the service working and test drive it for 30 days.
HI @Terry65
why don't you want to port your number here? The porting problem could be a problem on the source end rather than PM's
Pm is prepaid and usually does not provide refund.  but you can try to submit ticket with CS agent here:
Terry65
All I would like at this point is my money back
@Terry65
check this link below to see if your number can be ported to public mobile. If it can, ask the customer support agents to help with the transfer:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
your prior mobile service needs to be active and you need to have the Sim card in your device to receive approval to port
hi @Terry65
the refusal was probably because the info provided was incorrect.
was the transfer request less than a month? where you are porting from? anyway, please call the porting team number I sent you and they will help
Terry65
Tried to transfer my old number but I was refused.  Public Mobile took the money but was unable to co nect me
HI @Terry65
yes, it always account setup and carrier charges you and porting will complete after
you still want the number to port into PM?  I will send you the porting team number to your Community inbox.  They will provide the status and will tell you what to do from here.  Basically they will reinitiate the porting to your old provider, you get a text form your old carrier and you reply Yes to complete the process
Please check your Community inbox for the number
@Terry65  Did you not try to transfer the number on activation ? Do you have a temporary number from PM ? Did you use the app to activate?
