09-29-2023 10:09 AM - last edited on 09-29-2023 10:14 AM by Dunkman
The person that referred me said I’m not showing up on their account. Their referral code is xxxxx and the e-mail is xxxxxxx
Edit by Dunkman: removed personal information
09-29-2023 10:44 AM
I joined in August and already received the $10 credit but the person that referred me said I’m not showing up on their account.
09-29-2023 10:15 AM
HI @PSOttawa
when did you join? it takes 72 hours for PM to process the referral. You should see the $10 credit on your My Account showing as Available fund. If you see it, then your friend will see his shortly after
if not, you will submit a ticket for your friend to CS agent here:
09-29-2023 10:12 AM - edited 09-29-2023 10:14 AM
@PSOttawa You should see the $10 one time credit in your account available funds with in 72 hours after activation . And they should see the $1 /1point depending on the rewards they are in with in 24 hours after activation .If it’s been more then 3 days ask support that it was applied correctly
send a private message To CS_Agents click
VVVVV Link below VVVVV
