Charged twice
Fairy1
Charged twice! Two different amounts $ My regular bill is $33.90 but I signed up for a new plan $33.90 ! This month 2 different payment for 1 account !
7 REPLIES 7
@Fairy1
You will be charge once on the new plan.
golfball
@Fairy1 wrote:
So does that mean next month I will only be charged once ? Month to month plans !
@Fairy1 Yes, as long as you do not switch to a new plan you should only be charged once.
Fairy1
@Fairy1
You will be charged for you old plan plus your new plan if you click on NOW to change your plan. This is normal since PM is a prepaid service. There are no refund for unused days.
You should have click on Your Next Renewal Date so once the old plan expires…the new plan will take over.
Fairy1
  • I used Change Now on Sept 8 2024
Fairy1
  • I have only one phone number! Public Mobile had a deal they sent to me in a text and it was better than what I had so I bought it ! I would say 10 or more days ago !
hi @Fairy1
did you sign up the new plan with a new account? if so, that is normal as you have 2 accounts.
if you change plan, did you use Change Now option? if so, you used the wrong option, there was a Change on Renewal option and you should use that
if you use Change Now by mistake, may I know how many days into the cycle you made the plan change? Day 1? or day 10? or so?
