3 hours ago
2 hours ago
Never any extra charges here. If you didn't complete the port before the subscription renewed, you're out that money unfortunately. I would always advise initiating the port a couple days before the subscription renewal to avoid this situation.
3 hours ago
@esimeissue wrote:Extra charge upon porting number to Rogers
$40.68 on Nov 28, 2024
@esimeissue No such thing as extra charges at PM. I suspect what happened is your plan renewed before you ported out. If you believe it was an error on PM's part contact them at the link below:
3 hours ago
@esimeissue porting to Rogers should have automatically closed off your Public Mobile account. Contact support agent and ask them to look into it.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
