11-14-2023 07:03 PM
Hi all!
I'm thinking of changing my subscription to the $34 dollar 5g promotion. Was wondering if my add-ons will follow me to my new subscription? Thanks in adance!
regards
RR
11-14-2023 08:58 PM
??? Yes.
11-14-2023 08:45 PM
So, my add-on US minutes should be okay...
11-14-2023 08:19 PM
As @Hollister said, data add-on's are incompatible with 5G unlimited plans. They'll stay on your account, but they won't work with the unlimited plan. If you really still want access to them you could choose the 4G version of the same plan, but know that it isn't unlimited.
11-14-2023 07:14 PM
If you have any data add ons they might be put into the following group in your self service account: Incompatible Data Add-on
11-14-2023 07:07 PM
@AArrbilly Changing plans won’t effect your old rewards there tied to your account not your plan , just do t ever opt in to the new point program . I change plans often and have always keep my old regards I can confirm . Have a peek
11-14-2023 07:04 PM
Hi there @AArrbilly
You will not lose your current rewards/add-ons if you change your plan. If you were a part of the old rewards program, you will not be switched to the new Public Points program unless you choose to join.
Have a nice day.
