Friday - last edited Friday by computergeek541
I recently signed up with Public Mobile with a 50% off for first three months Amazon promo. If I change my subscription plan right now, will I lose this promo? Thanks!
Friday
Also do remember that you are very likely to lose access to low value plans in self-serve the moment you upgrade to a high $ plan.
Friday
Thanks for the replies! I contacted support and they said that the promo would be lost.
Friday
@Tanjo Most like will but you can confirm with support , if you see a plan you like better thou make sure to change plan on renewal option and not immediately or you lose money in current cycle . pM is pre paid and no refunds
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
and here’s link to ask support for confirmation if you lose 50% off or not
hi @Tanjo likely you can't or you will lose the 50 percent off. The details of the terms would have specified that
