Change subscription - Issue
mihir_modi1365
Hello,
I have changed the subscription from app but when I saw the offer, it was showing 250 international minutes of India. And I changed the subscription right away.
but, then I checked the new subscription, it doesn’t show 250 international minutes of India.
I have attached the pictures of offer I saw and new subscription.
please let me know.
2 REPLIES 2
slusagm
did you use Change on Renewal both times? if you did, things should be ok and still can be fixed.  Ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
Chalupa_Batman
Hello @mihir_modi1365
If you have any concerns about your plan you can contact a CS Agent to confirm the offer.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
