Changing plans
Gigsdo
If I change to a different plan from PM will I need a different sims card
I have the $35. plan with only 2.5 data
could switch to a cheaper plan with more data since I will be losing my rewards anyhow.
@Gigsdo  No you don’t need a new sim in your account you can” change  plans “to whatever plan that’s there to change to . And remember to change plan for next renewal and not immediately or you lose money on your current cycle
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
@Gigsdo
You will be the same SIM. Everything is done through your online account so login to your account online or the PM app.
Phil_Adelphus
@Gigsdo  No you don't need a new sim card, just select the "change on renewal" option so as not to lose what you paid for with the current plan.  Bear in mind that if you switch to a cheaper plan you will lose the bonus data you got for switching from rewards to points.
