10-07-2022
01:40 PM
10-07-2022
02:17 PM
computergeek541
10-07-2022 02:17 PM
@deelite wrote:Hi there,
if I change my plan will I lose my add ons or rewards?
There are some cases in which a plan change can cause a losss in rewards. This happens when a customer performs and immediate plan change. Fortunately, this is temporary and the rewards will get applied again for the following renewal.
10-07-2022 02:16 PM
@xavier_27 wrote:If you use the same email i dont think you will lose your points but you add ons im not sure.
As above, add-ons are not affected by plan changes.
10-07-2022 01:43 PM
10-07-2022 01:43 PM
@deelite No you won't lose rewards like autopay/RAF/loyalty as they're tied to your account and not your plan. However, you might lose any bonus data if you activated with a promo offer depending on the terms of the promo and if you're on a grandfathered plan, then you will not be able to change back to it once you change plans.
10-07-2022 01:42 PM
NO.
Add-ons and rewards are tied up with your Account not plan so you can switch plans every month if you want.
