11-20-2023 10:27 PM
Hello Public Mobile Community,
I have a few questions regarding my subscription.
I paid for 90 day cycle until Jan 12, 2024. What happens if I cancel Public Mobile before my subscription cycle ends? Do I get my remaining balance back?
Currently, I set my subscription plan change to $34/month as of Jan 13, 2024. What happens if I change my subscription now? Do I get a refund for the difference?
Also, I changed my subscription on Oct 15 to get the benefit of the promotion (5G 3, 50G per month, $40/month for $45 on 90-day advance payment). I should have been charged $120 for 3 months with the promotion deal but I was charged $135.
Thank you for your help with this in advance!
11-20-2023 10:35 PM
Thanks for the reply!
The tax is 5% which should have then be only $126.
11-20-2023 10:32 PM
if you use Change Plan now , you won't get the remaining balance back
better to use Change on Renewal to schedule the plan change after your current 90 days cycle. PM usually will honour a schedule plan change as long as you make the Change on Renewal request when the deal is still available. Please keep a screenshot of the schedule plan change for yourself
For the charge $120 vs $135, any chance it was just tax on top of $120?
11-20-2023 10:31 PM - edited 11-20-2023 10:32 PM
1a - you would have to port out or ask support to cancel before your plan ends. 1b - No.
2a - You would pay now and lose all that you had paid for the previous plan. 2b - No. See 1b above.
It sounds like you might have got on to the 30 day plan. Are you sure about your plan expiry?
11-20-2023 10:31 PM
#1...nope
#2...nope
# 3...use this link to message Customer Support re: if you were overcharged.
11-20-2023 10:30 PM
@vichee07 wrote:Hello Public Mobile Community,
There are no refunds and no credits given for partially used plans. To avoid losing the remainder of you existing plan, avoid using the immediate plan change option. Instead, pre-schedule a plan change to occur at the time of the next renewal.
