11-06-2021 12:40 AM - edited 01-06-2022 03:57 AM
I’ve changed my email address today and it’s not the same one I signed up with , is it possible to change it without closing my PM account and opening another one?
11-06-2021 04:33 PM
@Deano53 wrote:For the person or persons who directed me how to change my email address… a big bravo to you it’s all done and am very grateful for your help😊👍
You can easily find who was first to advise you of steps to be taken to change your email.
If you click on that little thumb up button (bottom left part of the message) person who helped you will benefit.
It is very nice of you to come back and report your issue has been resolved and give kudos to helper. Not many people do that... as soon as issue is solved, never hear from them until next issue...
11-06-2021 03:23 PM
11-06-2021 02:58 PM
@Deano53 happy you are all set..
so.. you Self serve email matches the Community login email? they have to be the same for Community Rewards to apply on your Account.
11-06-2021 02:55 PM
11-06-2021 01:09 AM
Awesome thanks so much 👍😊
11-06-2021 12:46 AM
Contact a CSA to change self service email account.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
11-06-2021 12:46 AM
@Deano53 Yes, you will need to contact Public Mobile CS Agent to get your email changed.
If the Community is stumped by your question or if you have an account specific issue, then it’s time to contact our super-knowledgeable Customer Support Agents. Here’s when and how to contact our Customer Support Agents:
