02-09-2023 06:32 PM
I took my SIM card out of my old iphone and put it into my new iphone but it does not work. The phone recognizes the Public Mobile network but I cannot text or call. I have rebooted the phone, reset network settings, toggled airplane mode on and off, manually selected the Public Mobile network, but nothing works. It all worked fine in my iphone 8 but not in my iphone 12. Please help. Thanks.
02-09-2023 11:00 PM - edited 02-09-2023 11:00 PM
@nbanman wrote:Bought it used privately. We checked and it's not blacklisted
you checked at devicecheck.ca ?
private sell is dangerous, search here and you will see many "smart" guys got tricked
02-09-2023 08:22 PM
@nbanman wrote:I took my SIM card out of my old iphone and put it into my new iphone but it does not work. The phone recognizes the Public Mobile network but I cannot text or call. I have rebooted the phone, reset network settings, toggled airplane mode on and off, manually selected the Public Mobile network, but nothing works. It all worked fine in my iphone 8 but not in my iphone 12. Please help. Thanks.
Turn off VPN on your iPhone if you have set up VPN.
02-09-2023 08:05 PM - edited 02-09-2023 08:06 PM
Try ANOTHER person's SIM card in the newer iPhone to see if the device can read and connect to their account/network and function normally (calls/texts both in and out, + data functioning)
Buying a device privately (especially from an unknown source) is extremely risky and may end up in problems for the purchaser.
02-09-2023 07:03 PM
can you confirm if your see the phone connects to the network? any bars ?
so, does data work?
make sure you update carrier profile
02-09-2023 06:59 PM
@nbanman does data work? turn off the wifi and test it.
Deregister the old number on the iphone: https://selfsolve.apple.com/deregister-imessage/
Set up your new phone number on the iPhone:
02-09-2023 06:52 PM
02-09-2023 06:51 PM
Try deleting the old Carrier profile(s) in settings, then reset the phone.
02-09-2023 06:50 PM
@nbanman Yes it still works in old phone ? Or yes you shut down in settings general / shut down
02-09-2023 06:45 PM
yes
02-09-2023 06:45 PM
02-09-2023 06:41 PM - edited 02-09-2023 06:47 PM
@nbanman You can also try going to settings on the iphone go to general and at the bottom there’s option to shut down and wait a minute and turn back on
adding shutting down in settings is not same as rebooting this will take the iPhone offline completely and ping it back on to the server
02-09-2023 06:38 PM
Phone might be locked or blacklisted.
Try your SIM in Another unlocked phone. No reason SIM not to work in new phone unless you managed to damage it somehow during swapping process.
02-09-2023 06:36 PM
@nbanman Sorry I responded quickly you already rebooted the phone … is it possible the SIM card got damaged when you took out of old phone to put in the new one , can you try the SIM card back in old phone and all services work still
02-09-2023 06:34 PM
@nbanman Where you got the phone from??
did you get the phone. from trusted source?? maybe check if the phone is clean for piece of mind:
https://www.devicecheck.ca/check-status-device-canada/
02-09-2023 06:32 PM
@nbanman Did you reboot the phone
