11-10-2024
08:45 PM
11-11-2024
01:34 AM
computergeek541
I recently moved to another province and changed my number to one with a local area code. I did not change service providers. The only issue is that when I text somebody, it shows on their phone as being from my old number. Is there a fix for this so texts will show as coming from my new number?
11-11-2024 10:15 PM
11-11-2024 10:15 PM
It worked! Thanks so much, Luddite!
11-11-2024 02:13 PM
@GMatt "The only issue is that when I text somebody, it shows on their phone as being from my old number"
Go to Settings on your phone
If that fails, try logging out of your Apple ID, logging back in and resetting the details.
11-10-2024 11:47 PM
You are thinking about a factory reset so DON'T do that.
No you won't lose anything if you reboot your phone. It just resets all you apps. Just power off your phone then power back on.
You can also do a hard restart. Push the volume up button then the volume down button and hold the power button until you see the Apple logo and let go. It will restart and enter the pass code to turn your phone back on.
11-10-2024 09:30 PM
Hi DennyCrane,
I do have an iPhone, and so does my wife. It was when texting her that I was first made aware of this problem, but other people have also reported it to me. I don't know whether they have Android or iPhone.
11-10-2024 09:26 PM
Thanks. If I reboot my phone, do I lose all my settings, photos, passwords, apps and everything else? Or do you just mean turn it off and turn it back on? I tried doing that and it didn't change anything.
11-10-2024 08:50 PM
Did you reboot your phone after changing your number?
If that didn’t work. Contact a CS_Agent to help you update your number.
11-10-2024 08:49 PM
Are you using an iPhone? Is it possible it's iMessage that's confused? Does it do the same thing when texting Android? Does it show your new number on their call display when you call them?
