Change plan
05-12-2022 03:23 PM
I tried to change my plan before autopay renewed it and couldn't so it was renewed on the 10th on the plan I'm trying to change. So I still can't change it. It says pick your plan but no options to choose from. I want the $60 or $70 plan but I think the $15 it renewed should count towards the new plan as it is not my fault I couldn't change it. I have a 4gb data promo i want to keep or renew as well. Can someone help please?
Plans
05-12-2022 09:43 PM
If you really need the data asap you can change plan immediately after you resolve browser issue which means you lose your 15 plan immediately and then try to get a CSA to credit your available balance with the 15.
05-12-2022 06:58 PM
Being unable to see any plan options is usually a browser issue. Since you wanted to greatly increase your plan contact customer support and explain your issue. If the CSA grants your request be prepared to immediately manually top up your account the difference between the $15 and the new plan. Ask for a review link when your done if the CSA grants your request.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-12-2022 03:27 PM
HI @cros1378 So, you certainly you successfully made the Plan Change before the 10th? What do you meant by "It says pick your plan but no options to choose from. "? If there was no plan to pick? how you made the change?
It sound to me like the plan change wasn't successful as you didn't see the plan and you wouldn't be able to pick and submit the plan change
You can try to open ticket with PM CS Agent and see if they can upgrade it for you. To open the ticket, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
