05-12-2022 09:07 PM
Need to reset my account password and tried doing that but asking me for ‘my father’s birth year’ which i never registered. When i put it in, it was incorrect. Is there another method to reset the password? What else can i do?
05-12-2022 09:10 PM
If the reset password is not working, you will need to customer service agent (CSA).
You will need to contact customer service agent (CSA):
https://www.publicmobile.ca/en/on/chatbot.
Type: I can't login. Follow the prompts to submit ticket.
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours. Check your private message inbox (envelope in upper right corner of website).
