Change of plans after payment..
Bobbi224
I went to change my plan, not realizing that the payment already came out of my account (I didn't get a text saying it was due in however many days). Is there a way that I can pay the difference in plans and have them switched?
Tiprix
@Bobbi224, as the other users mentioned new plans should be applied at your next renewal date, in order to prevent double payment.  In your case, I would contact the moderator via private message and see if they can assist you.  Make sure to explain what happened in detail. Good luck.
hycm53
Since PM is a prepaid service, if you change plan immediately your previously payment will be lost and won’t get refund. You should set new plan be changed at your renewal date.
Metal1967
@Bobbi224
You would have to do a plan change set for your next renewal date..what you suggested/asked is not possible..
