Change of Plan and/or Change of Phone = NO LTE
ZeeYow
Hi,
I have changed my phone and also had my plan upgraded to the 15GB LTE. Now I am not getting any LTE service. It is brand new Samsung phone and new plan. What do I need to do please ?
Many thanks,
15 REPLIES 15
ZeeYow
Yes, Canadian version. One physical nano SIM and one eSIM. Unfortunately, can't use PM for eSIM 😞
@ZeeYow   was that a Canadian model of S23 ?
Freedom sim always has a "magic".  We usually use it to update APN  on phones that have the APN menu locked.  I guess something similar happened here.  But it is a great lesson to learn, Freedom sim can give us freedom  🙂
happy to know you are all good now, Enjoy your great phone
ZeeYow
I feel it is important to update you all on the situation and solution. May be someone else has the problem and could benefit from i
  • Phone = New Samsung S23 Ultra
  • SIM not working for data. Voice calls fine
  • Put the SIM in the other phone and it works
  • Put another PM SIM in Samsung S23 Ultra and again same issue - Voice ✔️ - Data
  • It is clear that the issue is with new Samsung. So contact Samsung Technical Support. Tech support does all sorts of tests including resetting the network setting, resetting app permissions, running in Safe mode etc. No Luck 😞
  • Take the phone to Samsung Authorized Repair center and they want to check it with SIM of another operator. (I did not have it - we are all PM customers). So, he puts in Freedom SIM and it works !! So, he says nothing wrong with device !
  • Takes out Freedom SIM and pops in PM Sim - Voila it starts working. Get LTE immediately
So, thank you all for your help and suggestions. I don't know what was the issue. It looks like it was some network config that was 'stuck' and with new network it allowed it to get back. I dont know - it so happened that it has started working !
I thought I will share it - others can perhaps help in this freak issue 🙂
@ZeeYow   then no need to reprovision the sim, the sim is good
The new phone, does voice work? or nothing work?
if nothing works, check if the phone is blacklisted: https://www.devicecheck.ca/check-status-device-canada/
if it is confirmed clean, then tell us what is the brand and model of the phone
(Update: re-read your post and you said calls work, then it is a device issue.  now, it is a matter of what brand and model is it)
ZeeYow
Thank you. I have put the SIM in the other phone. It works - I get 4G symbol and data works.
In the new phone - same thing - NO Data - Calls work fine.
Should I request reprovisioning of the SIM ?
Thank you very much,
@ZeeYow   I think there were reports of data issue after plan switching before, but it was earlier when 4G speed plan was introduced.
Do you have another phone to test the PM sim?  it can force a sim reprovision and that could resolve your issue
if not, then open ticket with PM support and they can reprovision the sim/account for you
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
ZeeYow
Tried it - no luck 😐
ZeeYow
  • Network Mode: LTE/WCDMA/GSM (auto connect)
  • Access Point Name:  Mobile Internet (sp.mb.com) SELECTED
  • Network Operators: Select Automatically (SELECTED)
ZeeYow
I have tried to
  1. Restart the phone
  2. Take out the sim and re-insert
  3. Reset the APN settings.
Any other way to reset the network settings in android 13
ZeeYow
Its not the speed. There is no data service 😔
@esjliv wrote:
@ZeeYow - if you changed your plan recently, note that the speed change from 3G to 4G (LTE) can take up to 48 hours to take effect.
What options do you see in the Mobile networks/Network mode of your phone?
The 48 hours for speed change is true, but that wouldn't cause the LTE network to be disabled.
will13am
@ZeeYow , quite often with Samsung devices, a network reset cures connection ills.  You might want to give that a try.
@ZeeYow  Try to reboot phone and check that your network setting are on 4G /LTE
There's no difference in available networks between either 3g or 4g plans.  Which Samsung model is it?  Ensure that that auto network option (LTE preferred) is selected for network type.
