Change my 4 digit pin
Ahmed9
I forgot my for digit pin , I changed my banking information a thought it would renew but it didn't and I have to do it manually by calling 611 but I forogot my password. Why can't we just pay for it after we updated on  the website ??? Help need my service money is there but can't seem to apply it without the 4 digit pin 😡
DavidChow
I have this exprience before, it's very terrible.
@Ahmed9
but in your case, after you updated your credit card, you need to use this link to load enough fund to renew the plan
https://myaccount.publicmobile.ca/en/account/payment/funds/card
@Ahmed9
please use this direct link to update your 4 digits account PIN
https://myaccount.publicmobile.ca/en/account/reset/pin
Chalupa_Batman
Hello @Ahmed9
You just need to log into your account and you can change the 4 digit pin. Here's how.
Log into your account, then go to Profile on the left side, then the next page, right side under Account Security Info is your PIN Password. Click on the pencil to change it. It's that easy.
If you're still having issue logging in, please create a ticket.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
