I can't change my address
Tetiana71
i want to update my address and it says Invalid address
1 REPLY 1
hi @Tetiana71
is that an apartment?  if so, try the address only first without unit number.  Also, don't past the whole address, slowly type it out and let the Lookup starts working
if you really cannot update the address, ask PM support agent to help
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
