12-15-2023
08:08 PM
12-16-2023
01:53 AM
computergeek541
Currently I have $5 off per month for 90 days and $2 off per month for autopay. If I change to $40/month, will I lose all my discounts?
Thanks!
12-15-2023 08:19 PM
Hi @Momomomomo,
You will not lose your discounts! The legacy rewards are attached to your account and not your plan. This means that you can switch plans as often as you'd like without fear of losing your rewards. The only thing that would cause you to lose your rewards is if you close your account or if you switch to the new points system.
12-15-2023 08:13 PM
@Momomomomo No you will keep your rewards the same I can confirm I just switched plans and kept mine have a look
12-15-2023 08:12 PM - edited 12-15-2023 08:13 PM
@Momomomomo As long as you don't switch to Public Points you won't lose your auto-pay. The price for 30 days instead of 90 days would depend on the plan. Usually the 90 day plans are $5-$10 dollars less than the same amount of data for 30 days. You can just change plan to something that suits you better. Just don't change now, make it change on renewal or you'll lose the rest of your 90 day plan and it's not pro-rated
