Change address
SL-W
I have moved from Ontario to Alberta.  I am trying to update my profile but it won't accept my new address.
will13am
@SL-W , the address can be updated using the app.  Make sure location permission is enabled.  It could take many tries, but it will eventually work.
EB0
@SL-W
You have a different account than your husband, just creat a ticket under your name and ask support for help to change your address
SL-W
Invalid Address.  My husband had to get help earlier to change his.  They wouldn't let him update mine at the same time.
SL-W
ZylAL
Can you advise what happens when you try to update the profile?  Error messages?  That would help us in troubleshooting it for you.
Thank you
