07-28-2021 04:50 PM - edited 01-06-2022 03:04 AM
I would like to change my autopay card to a different card. Can you please give me guidance on that?
07-28-2021 05:01 PM
You can also find "manage my card" in teeny , tiny letters in the middle of the payment page under the credit card box.
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from the moderators.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot
07-28-2021 05:00 PM
i suggest you can Remove your credit card and Logout and after 2 minutes log in and re entered.
just make sure your credit card number and your address match the same,
sometime your typing it but is a one word or letter or number is a wrong or is missing just make sure for it.
How To Update Or Remove Your Payment Card
To update or remove your credit or Visa debit card details, sign in to Self-Serve. Once signed in, click on the ‘Payment’ tab, then scroll to the bottom of the page and select ‘Manage my card’. Here, you will have the option to either select ‘Replace this card’, where you can enter the details for your new card, or ‘Remove this card’. You will need to review and confirm this change to your account and then you’re all set..Remember, we accept credit cards (Visa, MasterCard, American Express) and Visa Debit cards that have been issued by Canadian or American financial institutions and are associated with addresses in Canada or the U.S. If you are using a payment card, leave the apartment/suite number in the payment information section blank.
Good Luck
07-28-2021 04:51 PM - edited 07-28-2021 04:55 PM
@Yanqingyang wrote:I would like to change my autopay card to a different card. Can you please give me guidance on that?
Log into self service and choose the “Payment” tab. Scroll to the bottom and choose Manage my card. https://selfserve.publicmobile.ca/
