06-03-2021 08:22 PM - edited 01-06-2022 02:49 AM
I would like to increase the number of rings my cellphone rings before it transfers to voicemail. Presently it is 3 and I would like to increase to 5 or 6
7 hours ago
HI @zcbm
not everyone able to get it working now because not everyone has conditional forwarding working
please ask support agent to fix your conditional forwarding first. Submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
7 hours ago
That didn't work. What do you do after entering the sequence of numbers?
a week ago
I’m getting the above error when entering that code. Anyone know of a fix?
Thank you
05-15-2022 11:00 PM
**61*17783240667*11*30#
I used the above code on 2 android phones. Both have android 11. One is a Nokia and the other is Motorola. A friend with another carrier used the same code with an Android 10 Motorola.
30 will give you 6 rings or so. Substitute your voicemail # in place of mine. Works perfectly. You can find the voicemail # under "call forwarding" settings.
06-03-2021 11:07 PM - edited 06-03-2021 11:08 PM
that's very nice of you
I like the fact that you have been going through old threads and introducing past solutions to the OP. especially something like that, because it was the best answer.
what I would do is re-create that post and make it your own.
06-03-2021 11:02 PM
@softech wrote:You guys not just know everything.. but remember everything too 👍
No that was just plain ol' search.
There's no reason why you can't take what someone else wrote some other time and copy it or re-word it or whatever. I see it on rare occasions like hey...that's my writing. But I personally try to re-word things so it's not a straight copy.
06-03-2021 10:58 PM
06-03-2021 10:54 PM
This post appears to be the first mention of it here by a user that is actually still around. But the dial code is from way back as a GSM code that has been carried through.
06-03-2021 10:50 PM
We found you.. thanks @gpixel !!!!
06-03-2021 10:49 PM
it was me 🤫
nezgar
06-03-2021 09:11 PM
cool.. i just copy and paste his post directly so he still deserve the credit 🙂
Also, thanks to whoever found this or post it the very first time 🙂
06-03-2021 09:07 PM
@softech : geopublic was prolific here for a while and then he dropped out of sight. I hardly think he was the first to come with that 30 seconds thing though.
06-03-2021 08:33 PM
@rpurfurst wrote:I would like to increase the number of rings my cellphone rings before it transfers to voicemail. Presently it is 3 and I would like to increase to 5 or 6
To give you a visual, and add to @softech post...
this is what you dial to see what your current setting is already set at:
*30 seconds, which equals 5 rings, the maximum allowable.
Then you will see your current setting, looking something like this:
to change to 30 seconds, this would be entered:
**61*19025804001*11*30#
06-03-2021 08:24 PM - edited 06-03-2021 08:26 PM
hope this helps, Credit goes to @geopublic :
The number of rings is determined by the 'number of seconds to wait' before forwarding the call to your voicemail. Get your PM voicemail number from your Phone Dialer settings.
Dial this sequence: *61 *16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
SAMPLE: *61*16475804001*11*20#[SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail. Best to check mailbox.
Solved: Number of rings before voice mail? - Community (publicmobile.ca)
