Cha-Ching Msg from 611
dejavu89
Hi,
I got the Cha-Ching message from 611. But I don't see anything in the account or the rewards portal. Am I missing anything?
13 REPLIES 13
Hi @dejavu89
I am on the old system too
Just open a ticket with PM and get them to look into it
dejavu89
Hey. I don't see any 'Friend Section' at all. Can you please share a screenshot so I am sure I am looking at the right place
HI @dejavu89
With the new Public points, the friend section will only show you the amount and not the phone number
Open a ticket with CS agent to confirm if those referrals are missed
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
dejavu89
There is no Refer-a-Friend section as such or a down arrow on the right side of anything like that. Maybe difference between new and old rewards
In the "My Rewards" portal, click the down 🔽 arrow on the right side of "Refer-a-Friend". At least for me on the "old rewards", the last 4 digits of the phone numbers of those whom I've referred show up under there...
dejavu89
I don't see any referral phone numbers section
CountyDownIeUk
Did you look into the list of Referral phone numbers...got an extra??
HI @dejavu89
Ask your friend if he got the $10 on his My Account.  He should see it as Available Fund wtihin 72 hours of activation.
If he does not have that too, then the code was not entered properly
If he has the $10, then it is a matter of time you will see it on yours
Metal1967
@dejavu89  not sure how the new public points work.. not going to be anything to post on instagram.. lol.. but every little bit helps..😬
dejavu89
yes new referral, I got it last week. I am on new public points. Was just wondering if there is any indication in the portal until the first 30 days pass for the new referral?
Metal1967
@dejavu89  your getting a dollar or two eventually.. stay tuned
HI @dejavu89
is the Cha-Ching for new referral?
are you on the new or old rewards?  With new Public Points, the friend referral will show up there much later, maybe couple days to 2 weeks.
And try to make sure it is not cache issue. Clear cache and then restart the browser to re-login My Rewards site
Or use Private or Incognito mode to check
walker1
@dejavu89   Sometimes there's a delay.  Check back later in the evening.
