Cant send SMS and cant receive calls after porting number
serget
I can call a d use data but nobody can call or text me
serget
Please send the porting number to my dm. I did not receive it yet
serget
Yea i can make outbound calls and use data. Its been like this for a week where the chat says only 5 hours wait
Yummy
Most likely porting was not complete or it failed.
Does your account says it is Active? and shows your plan?
Can you at least call out? What number other party sees? Did you follow porting procedure to the letter?
serget
HI @serget
can your PM sim connects to PM network? can you make outbound calls?
if you cannot make outbound calls, it is not porting but an account problem,   please submit a ticket with CS Agent here:
But if you can make outbound and just not receive inbound calls, then first reboot your phone and check agian
if same,  wait an hour and try again (porting can take an hour after you replied YES).
If still no inbound, then call Porting team for update.  I will send you the porting team number, check your Community inbox
