02-16-2023 07:37 PM
I just received my first sim card, created my account and got my number. I can call out and send and receive text messages but can't receive calls or use internet. I've don all the troubleshooting but it's still not working. What do I do?
05-09-2023 04:32 PM
@carmenking123 sent, please check your Community inbox
05-09-2023 04:26 PM
I have the same issue...can you send me the same number?
02-16-2023 08:04 PM
@CM45 Can you try the SIM card in another device and see if services work and if it does try it back in your phone and see if that helps , after trying @dabr suggestions otherwise you may need to ask support to reprovision the SIM
Watch for reply top of page to the
Right ( envelope image )
02-16-2023 08:00 PM
@CM45 How long ago did you activate your new number/account?
Keep rebooting/toggling airplane mode on/off for the next hour to see if everything gets sorted. Did you try your SIM in another phone as suggested earlier?
02-16-2023 08:00 PM
@CM45 wrote:I chose a new number I didn't port one
The incoming call part sounds like a provisioning issue. Contact customer support agents via chatbot.
02-16-2023 07:57 PM
02-16-2023 07:57 PM
Thanks, I checked everything and its good but still not working
02-16-2023 07:46 PM
@CM45 For the data you need to ensure you have the correct APN settings on your phone. Here's couple of links that might help.
Android: https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-android-phone
Iphone: https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-iphone
02-16-2023 07:45 PM
@CM45 Did you port your number to PM and miss the 90 minute window to reply YES to confirmation text from old provider ? If yes there’s a porting team to call for live support can help , I’ll send you the number private message
02-16-2023 07:44 PM
Sorry to hear about your troubles. Did you port over a number from another carrier. Or started a new account with a new phone number
Can you try your SIM card in another working phone. That would help determine whether hardware issue versus PM service problem.
A few basic trouble shooting advice:
Reboot phone
Network reset of phone.
02-16-2023 07:43 PM
@CM45 , did you do a number transfer during the activation? If so, it can take a bit of time for the process to complete. Also, did you confirm the transfer from your old service?
