02-09-2021 11:50 AM - edited 01-06-2022 02:04 AM
i have the $25 plan so i have unlimited talk but when i try to make a call it says cannot complete your call you dont have an active long distance addon. this started yesterday and im frustrated that i cant make important phone calls. ive tried turning my phone off and on again and nothing is working. incoming calls work fine.
02-09-2021 12:17 PM
@Dunkman : It started yesterday. I observed and commented on it after the second or third or so. A conspiracy theory might be that the company is pushing the old provincial plans out forcing people to go to current plans.
@Jaci : If you did an immediate plan change then you would have lost what value you had already paid for from the previous plan. There's no pro-rating or refunds here. Hopefully you were near the end of the paid term.
02-09-2021 12:10 PM
i got my plan updated and it works now. the provincal plans are glitched!
02-09-2021 12:05 PM
I am wondering if system problem if multiple people are having the same issue. Another similar case this morning.
Maybe try the SIM card in another working phone. This helps determine whether hardware setup issue versus PM service problem.
A network reset of the phone might be worth trying.
02-09-2021 12:05 PM
@Jaci : Are you possibly on an old provincial plan?
02-09-2021 12:03 PM
i have tried added 1 and it doesnt make a difference
02-09-2021 11:59 AM
@Tracyo wrote:I’m having the same issue right now
Are you certain you're subscribed to the $25 plan as well ? If you happen to have the $15 plan with limited calling...you likely run outta calling minutes until next renewal. You can also get the $5 / 500 minutes of Canada wide calling add-on to back up the $15 plan for when you run outta minutes.
02-09-2021 11:55 AM - edited 02-09-2021 11:56 AM
@Jaci wrote:i have the $25 plan so i have unlimited talk but when i try to make a call it says cannot complete your call you dont have an active long distance addon. this started yesterday and im frustrated that i cant make important phone calls. ive tried turning my phone off and on again and nothing is working. incoming calls work fine.
@Jaci hi try adding a 1 in front off number if that doesn't help put in airplane mode for 5 minutes then reboot
02-09-2021 11:53 AM
