Cant complete activation
Essa-8
App keeps logging me out
cant complete esim activation
eddieO
@Essa-8, you should have received an email from Public Mobile with the QR code to scan. Have you checked in your email's spam or trash folders in case it went there instead? If you are still unable to find the email you will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
Essa-8
Vpn not connected
also didnt get qr code for esim
DDM69
Are you using a VPN?  If so, disable it and try again.
