10-27-2024
12:24 PM
10-28-2024
12:38 AM
computergeek541
Any one having issue when transfer from fido to public mobile esim 2 days still not able to receive calls and SMS. However data is working bit not sms?
Joining Public
10-27-2024 11:42 PM
Thanks for the solution. Yes due to esim only can use one at a time, the sms was sent to my old provider and waiting for my approval before they can port to public mobile. It works now. Much appreciated
10-27-2024 12:44 PM
you got the text from Fido and replied Yes ? you rebooted your phone with the PM sim ? reboot it once more
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
10-27-2024 12:34 PM
Hello @Jng1
My first suggestion would be to do a network reset and then reboot. Then go into your settings and confirm the Public Mobile eSIM is set at your primary number. If not, set it and reboot. Start from there.
Also, if you place your Fido SIM card back in the phone, does it still work?
