Re: Important Update: eSIM QR Code Now Included in Activation Summary Emails
SheilaT1
Extremely frustrating. New account that ported phone number from Virgin, got the eSim and now have no data, or no cellular indicator, seems like the sim is not activated.  There should be an easier way to do this,  have opened a ticket but it's now a wait and see, and already been with out my phone for a few hours.  tried the email QR code and the mobile app, no go.  Likely physical SIM is the way to go.
2 REPLIES 2
SheilaT1
CS support was able to help. was due to an issue with the initial download of the original eSim.  They had me re- purchase another eSim, and that one downloaded correctly. working now, Thanks to Nathaly.
Hi @SheilaT1 iPhone or Android?
do you see the PM eSIM installed? check Settings ->Cellular or Sim Manager screen.  Make sure it is active or "Turn on this Line" as well as set as Primary
and try Reset Network Settings
