03-28-2023 10:12 PM
Hi,
I've been getting this message when I make outgoing calls since this morning. 6UT1. I can receive calls and send and receive texts
Troubleshooting I've done.
-Reset Network Settings
-Shutdown and restart phone.
-Put simcard in another phone restarted tried to make an outgoing call got the same error message 6UT1
Any Ideas?
Thanks
03-28-2023 11:03 PM
As you wait for CSA help, may trying adding +1 or 1 in front of area code before dialing your number
03-28-2023 10:15 PM
there are so many customers with voice trouble today, you are not the only one
try to change the phone's preferred network or network type to 3G only and see if it works better
if not, maybe you need to engage PM support for further investigation
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-28-2023 10:14 PM
@pistolpete_1980 , it seems like a lot of customers are having issues with calling feature. I suggest using the chatbot link and submitting a support ticket to have your account reset which should fix the calling problem.
