07-18-2023 01:37 PM
Whenever the safe ID verification code is sent to my phone number, my number does not receive it
07-18-2023 02:27 PM
@Lenen let's see if the porting is completed before you try to login My Account
contact your old provider with your free phone number , plus if they receive your porting request and if they can take your verbal approval
07-18-2023 02:22 PM
thats a free number tho, and does not accept verification. I cant pass thru the 'confirm full access" step
07-18-2023 02:21 PM
yes.
07-18-2023 02:15 PM
is there a chance that i change the number i registered?
07-18-2023 02:13 PM
@Lenen but are you porting that free number into PM?
07-18-2023 02:11 PM
my problem is the text doesnt come to my number because i have a free number
07-18-2023 02:09 PM
@Lenen are you trying to port in a number to PM with activation? If so, you got a text on your old provider to approve the number transfer yet?
07-18-2023 02:07 PM
Is there a chance to change the number that I registered?
07-18-2023 02:06 PM
Is there a chance to change the number i registered?
07-18-2023 02:03 PM
I am already at "Confirm for full access" using the phone number i registered but this number does not accept verification code. How do I change the number that i registered?
07-18-2023 02:02 PM
for "Confirm Full access" I cant because my number is a free number it doesnt receive verfication code
07-18-2023 01:55 PM
The 2FA code is defaulted to send by text. Just it Resend Code and it will give you the option to get the 2FA code by email, calling or text.
07-18-2023 01:49 PM
You ca have the code sent by email.
Use the resend code option and select email.
07-18-2023 01:47 PM
Have you just signed up? Or have you been here a while? Had you previously set up the new login system?
Click on the resend code link to find other options. Hopefully the email option will show.
